If anybody has any tips which would help that would be great
P.S would have uploaded a picture but i couldn't see a add attachment option :scratch:
Lewisgame wrote:I used a nylon wire wheel drill bit.No i havent yet tried that one, ill give it a go and see what it turns out like, what kind of results did you get after using it?
mattyc19991 wrote:Looked like new after doing it. I brought a PRC inlet and done it off the car before fitting. I kept at it and got a little edge off the rinkle look.Lewisgame wrote:I used a nylon wire wheel drill bit.No i havent yet tried that one, ill give it a go and see what it turns out like, what kind of results did you get after using it?
Lewisgame wrote:Ah i'll have to give that a try cheers! :bigthumb:mattyc19991 wrote:Looked like new after doing it. I brought a PRC inlet and done it off the car before fitting. I kept at it and got a little edge off the rinkle look.Lewisgame wrote:I used a nylon wire wheel drill bit.No i havent yet tried that one, ill give it a go and see what it turns out like, what kind of results did you get after using it?
perksy wrote:Alternatively paint it with aluminium paint. Makes it look like clean, fresh, new.... aluminium.If all else fails i might give that a go, cheers
James
