Thanks in advance
Shaun
ShaunCTR wrote:Arrrrrrr that seems decent stuff I'm using Poor Bhoys black hole stuff ATMpoor boys is just a regular polish AFAIK with fillers that will reduce the appearance of swirls, basically cover them up but won't get rid of them alone. but Gtechniq P1 is an actual abrasive or compound polish or whatever they're called that can actually be used for paint correction to remove swirls from clear coat.
*nub* wrote:I didnt read your OP but if you don't wanna spend £80 or so on a DA polisher kit with polish then what bluntcap said is what you need. takes a lot longer though!No worries bud, it's not so much spending the money on a DA it's the fact I haven't a fucking clue what I'm doing with one!!
ShaunCTR wrote:it;s not that difficult and with a DA theres little no risk. you could press it on your paint work four hours and not do any damage*nub* wrote:I didnt read your OP but if you don't wanna spend £80 or so on a DA polisher kit with polish then what bluntcap said is what you need. takes a lot longer though!No worries bud, it's not so much spending the money on a DA it's the fact I haven't a fucking clue what I'm doing with one!!
*nub* wrote:You can buy a basic kit with 3 pads and polishes necessary for £89 or so ? Got mine from cleanyourcar.co.uk. I find getting rid of scratches easier as removing swirls requires more technique and a proper clean pad etc or you just reinflict them but I'm always too lazy and in theory removing swirls should be quicker as ur removing less clear coat isn't it !DAS 6 on its own is 85 quid. Maybe an offer?
Lewis. wrote:I'll have a look later on for you dude and see what I can find.Cheers bud :salut:
