#3707102
I did mine in the summer, all I did was remove it from the car, sand down with some 320 grade paper until all the gloss had been taken off it ( and blemishes ) And apply 3 coats of laquer as evenly as possible giving them about an hour between each coat you can even sand between coats to remove and imperfections but I didnt. REMEMBER dont take the sanding too far or you will go through the laquer to the carbon weave. If your not very confident you can use a finer grade of paper it will take longer but will be safer. Just take your time :bigthumb:
