Our version of the Haynes Manual.
#3841436
Hi guys struggling fitting a skunk2 inlet mani and the skunk 2 70mm throttle body
We have fitted both and there seems to be a few vacuum hoses left over that dont go anywhere . Also having trouble setting up the skunk2 70mm throttle body as there is also a sensor left over from the oem tb . Any help would be much appreciated
Phil
#3841483
There's no hole on the left side for the crankcase breather. People either leave it off, or extent the pipe and fit it into the brake vacuum with a T piece. Not sure on the throttle body but I'm guessing there isn't fitment for the EVAP system. That'll need deleting and can be turned off when mapped.
