Those Complete Power Boosting & Drivetrain Mods..
Forum rules:
Please keep personal insults to yourselves.
Opinions and discussion are welcomed but the name calling and petty retorts are now becoming tiresome and getting in the way of what would otherwise be a great section with a lot of useful information.
Personally insulting posts and those serving little purpose except to incite argument will be removed and authors warned. FYI, we operate a multiple warning and automatic ban system.
By Rambo
#3850333
Can anyone help shed some light on where they ran there oil lines to there cooler? having a moment trying to work out the best and safest route. Tried the search but to no avail
#3850338
I've just replied to your comment in my build thread. But I ran them behind the manifold. Heat wrap around the cooler pipes. Through the gearbox mount and wrapped some old coolant hose around the pipes to prevent chafing. Run along the wiring harness and cable tie them to the harness. Over the top of the radiator (I think I also secured them by the battery) and you're there.
Some people put the hoses over the top of the rocker cover. But that looks pony.
By Rambo
#3850388
Lewisgame wrote:I've just replied to your comment in my build thread. But I ran them behind the manifold. Heat wrap around the cooler pipes. Through the gearbox mount and wrapped some old coolant hose around the pipes to prevent chafing. Run along the wiring harness and cable tie them to the harness. Over the top of the radiator (I think I also secured them by the battery) and you're there.
It seems easier to route it that way. Might look for some heat sleeving
Added in 34 seconds:
Collister wrote:Mine is routed on the drivers side of the motor pics on here
http://civictype-r.co.uk/forum/viewtopi ... 9&t=289166
What the route after they dip behind head light?
