Forum rules:
By Chris_Ep3
#3833081
Hi, Ive got a rbc manifold machined out to 70mm along with a 70mm skunk 2 throttle body and adapter plate. Ive bought the thermal gasket that fits in between the adapter plate and throttle body but is there a 70mm gasket that fits in between the rbc and adapter plate? Thanks chris
By baddohc
#3833134
Most people usually only use the one.
But if you want to use a gasket on other side. Any gasket for the 06 plus civic will fit. I'm using a blox one.
By B1LAK
#3835975
Orite mate, tegiwa sell a kit that includes the gasket and longer pipe thats needed when fitting RBC, i just got 1 they are £15 from there website. My adaptor plate and RBC are both 70mm, the gasket is 64mm i think, so just trim the inside if the gasket off after you put in your adaptop plate.
