#3866182
Hi,
I'm wondering if anyone's got an advice for me please?
My 2005 EP3 is occasionally not starting and I think it's because the battery has been in and out of the car too many times and it's caused the negative battery terminal clip to be "loose", the nut is tightened to it's maximum yet the hole has slack around the battery terminal. When it's messed around with I can then get the car started. When it's loose i'm getting nothing at all not even the clicking noise.
You can see the gap around the terminal in this picture of it : Image
any ideas gratefully received
