By phillll
#3865325
Hi guys,
Replaced the wipers on the fn2 and they’re hitting the drivers side a pillar. They are definitely the correct Bosch set (A402s).
Anyone suggest what could be the problem? Do I need to take the arm off and adjust?
By parsimony
#3865326
Did you check the length of the blade against the old one?
By phillll
#3865350
They are slightly bigger than the old ones, but the recommended size.
Problem solved though. Took the wiper arms off and adjusted :)
