Got an annoying clunk/knocking sound from somewhere on my suspension/steering
So, I needed to replace my inner and outer tie rod ends on my 2002 EP3, and I have some tein coilovers to go on also (all brand new), everything went fine fitting them. However when I now jump into the car after it has sat for say a good 20mins or so, the first time I turn the wheel left and right, I get quite a heavy clunk/knock/pinging noise from both sides, almost sounds like the spring is trying to relocate itself, but it will only do it that time, the rest of the drive is fine, until I get out, leave the car for alittle bit, jump in again and it will happen again. It's not terminal of course as I can still drive the car, but it's really annoying as to what it might be, can feel it right through the steering wheel and everything,
Hopefully somebody may have had the same experience, the only thing I haven't replaced are top mounts but they seemed ok
Anyways thanks in advance for any help and hope you all enjoy bank holiday weekend
Tac
