Loose pipe
Posted: Wed Apr 05, 2017 3:31 pm
by chappers51
Hi folks, just been under the car and noticed this pipe wasn't connected to anything. Is something missing or is it some kind of drain pipe?
Added in 10 minutes 13 seconds:
Re: Loose pipe
Posted: Wed Apr 05, 2017 7:55 pm
by 15repyt
Maybe for the air con drain? If your car has it.
Re: Loose pipe
Posted: Wed Apr 05, 2017 8:13 pm
by chappers51
Yeah it's got air con
Re: Loose pipe
Posted: Thu Apr 06, 2017 1:24 pm
by parsimony
Looks like the Evaporator Condensate Drain.
Re: Loose pipe
Posted: Thu Apr 06, 2017 2:22 pm
by chappers51
So it's doesn't connect to anything and nothing's missing then?
Re: Loose pipe
Posted: Thu Apr 06, 2017 3:56 pm
by HAMZAEP3
AC Draining maybe
Re: Loose pipe
Posted: Fri Apr 07, 2017 3:31 pm
by 15repyt
chappers51 wrote:Yeah it's got air con
Nope just drains water if needed from the air con.
Re: Loose pipe
Posted: Fri Apr 07, 2017 6:31 pm
When you use the aircon, condensation builds up on the evaporator inside the cabin. This excess water then needs to drain out from the heater box. It's not uncommon to see a puddle of water under the car in the summer when using the aircon.
Re: Loose pipe
Posted: Sat Apr 08, 2017 9:55 am
by chappers51
Excellent cheers lads
