By chappers51
#3862705
Just been changing the front pads on the car put the wheels back on, and come to the last nut was tightening it up and it snapped off :mad: I wasn't really using much pressure/force either, anybody know the correct/easiest way to replace it and where to buy a single lug? Thanks Craig
By 15repyt
#3862713
Have you got enough room just to smash it out of the rear or will it catch on something? If yes the it should be a easy enough job.
If not then you might have to remove the hub flange if you can buy the studs separate?
By chappers51
#3862719
Yeah I'll be able to hit it through as quite a bit snapped off
By chappers51
#3862724
Anybody know the correct length of the lug? Seen a few of different lengths and down not know which size to get? Thanks Craig
