- Thu Sep 08, 2016 4:40 pm
#3860131
I've been getting a P0132 code intermittently recently - 'O2 Sensor Circuit High Voltage Bank 1 Sensor 1'. Basically, the front lambda sensor is showing too high a voltage for too long, meaning that it senses the gases are too rich leaving the engine...It only happens when the car is cold and warming up. If I reset it after the initial warm up it won't come on again and the car drives perfect. Until it warms up the car feels very sluggish and even has the odd flat spot on occasion. The most likely thing is that the sensor has packed it in so i have a new one one the way in the post...
Anyway, I looked at the freeze frame data from the last too times the MIL came on and it came on under identical circumstances. Is that not strange?
RPM 1107
IAT 17*
TP 9.8%
ETC 59*
MAP 30kPa
LOAD_PCT 30.2%
RPM 1107
IAT 17*
TP 9.8%
ETC 59*
MAP 30kPa
LOAD_PCT 30.2%
In a Pyongyang restaurant, don't ever ask for a doggie bag.
