- Sun Aug 14, 2016 3:05 pm
#3859311
Hello fellow Type R drivers. Does anyone know the location of the alarm siren and how I can get to it? My 2004 EP3 has had a problem with the alarm going off. I found that if I lock the car with the outside door handle up and then push the door pin down then the car would lock and the alarm wouldn't sound. I'm guessing this means there is a fault with the ultrasonic sensor which I will replace at some point. Recently I left my car while on holiday and on my return the battery was slightly flat. I jumped started the car and everything was fine. This was about six weeks ago. I haven't been using the car much and today the alarm started to sound so I'm guessing the battery in the alarm siren is knackered. I know this is an expensive part and would just like to remove it. Does anyone have any pictures of it location? I've searched but can't find any pictures anywhere.
