- Fri Jul 08, 2016 8:24 pm
#3858077
Evening all , my son has a 2004 civic type R , that refuses to start.........checked through it for him cam timing spot on ,voltages and earths all present and correct, fuel pump primes and kicks in when it does rum for a very short time (some times starts and then cuts out , tdc sensor found to have a mark on the tip so replaced came up with P1361/2 still no start/run .
Checked as per Honda workshop manual .....end result honda recommends new ECU
We it the ullet and acquired 2nd hand ecu ,security relay ignition key with lock and lock set is it a straight plug n play sort of thing or is there any programming required ???
Plugged it all in reconnected attery ,turned ignition on green key on dash flashing indicating imobiliser not disarmed ,have i missed somthing or could e the new ish ecu,key ,relay n fos set up e fooo baahed ???
any help would e greatly appreciated
