By Shonk
#1192615
my car is in for this at the moment
and some other stuff
camber arm
Headlight motor
drive shaft cover
i seen the printout for a shedload of parts for the gearbox
new bearings set
something 1 and 2 i presume the fix
also something 5 and 6 do they replace something on 5th and 6th now as well?
the parts printout was 3 pages long
By Shonk
#1194842
Right it came back today
1st and 2nd are much much better not as clunky but it still clunks
when putting it into 1st when the car is rolling upto the lights
1st to second is still grinding when at high rev's
3rd 4th 5th 6th are very very very hard to get into and out of gear
it feels very sticky (note the out of gear also)
will this go away
ive heard of 5th and 6th being hard for a while but not 3rd and 4th
By undecided
#1297315
anyone know of a dealer close to lincoln that has admitted to actually finding the service bullitin for this fault and done it under warranty?
getting near the end of my warranty now and really want to get this problem fixed first, car is a 53 plate (24 oct 03, pre facelift).
lincoln honda have fobbed me off saying there's no problem but there blatently is, they insisted they couldn't find any record of a service bullitin on the issue either.
After I brought the issue up a second time they tried telling me that the bullitin was for 04 plates onwards! everyone else on here seems to be saying the bullitin is for 53 plates and below.
The closest dealers all seem to be owned by the same people so will need to travel a bit, just wondering if anyone knows of a reasonably close dealer that knows what they're doing. Don't think nottingham is owned by the same people so may have to try them unless anyone has a better idea?
Also does anyone know the bullitin number? would make life a lot easier if I could say request this doc from honda then tell me the problem doesn't exist.
any help would be appreciated
By RichE
#1298550
Grantham and i think its 496.
By Rtype
#1298551
Phone HUK mate, they will tell you themselves that there's a bulletin!
They won't tell you the number but will definitly confirm it!
By undecided
#1298625
RichE have you had this done yourself at grantham or know anyone who has?
I thought grantham was maybe owned by the same people as lincoln but maybe it's just lincoln who seem to be useless at spotting obvious problems.
any extra info on who you spoke to / what parts they replaced etc would be really helpful to know.
thanks
By undecided
#1357289
OK, took the car into Nottingham honda who've checked it over and now seem to think it's the clutch that's on it's way out and therefore causing the 2nd gear problem (although they also say it's got about 4,000-5,000 miles left in it).
The car has had this problem since I bought it (on 20,000 miles - now at 27,800), can this really be a clutch problem?
Since the problem has existed since I bought the car is it possible that it could be working so badly and yet have already managed at least 8,000 miles since the problem developed and be capable of another 5,000? That's at least 13,000 miles of driving since the problem started, would it not have failed by now??
Not only that, should the clutch really have got in such a state after less than 20,000 miles? I'd have expected much more than 20,000 from the clutch regardless of driving style.
Also while we're on the subject of clutches and since this isn't a warranty item, what sort of price would you expect a new clutch to cost?
Nottingham Honda have quoted £810 inc vat, is that good or bad??
Just hope they don't find anything else wrong, the rear suspension arm of my type r was replaced under warranty a few months back and the failure caused uneven tyre wear on one tyre. Nottingham Honda have noticed that tyre is now under the tread limit so that's £105 + vat for the tyre as well!
Damn expensive car this type r!
By RichE
#1357364
Get a second opinion from a respected dealer and dont pay dealer prices for tyres mate.Sounds like the gearbox to me but you may just have to live with it.Have you noticed the clutch slipping at all?Plus you would probably be well advised to replace both rear tyres if the other one is worn as you will have different grip levels on the rear.Grantham Honda are well aware of the second gear problem and fix, if Dave is still there ask if he can have a look at your car.
By johnny 5
#1376240
I have the same problem, asked my local dealer to look at it when i took it in for a service last week.
They attempted to solve the problem the easiest way they could, by changing the gearbox oil. However, they asked me to run it in for a week and get back to them. I have run it in over the last 4 days, still the same, no improvement at all, if any, the nothciness has become more 'clean and crisp' making the gear the gear change even 'sharper' when crunching into 2nd.
I have re-booked my car back into the dealer for Thursday, where i would imagine they will inspect the car in further detail. Should i print this document out and bring it along with me and 'suggest' that it is related to this issue (it has to be) or should i just wait for them to diagnose the problem themselves, which could result in the mechanics claiming its the clutch?! What have others done and what was your outcome?
By undecided
#1376262
johnny 5 wrote:I have the same problem, asked my local dealer to look at it when i took it in for a service last week.
I've had all kinds of excuses from honda so far...
1) there are no known gearbox problems with the type r
2) the known problems are only with cars 04 onwards
3) the problem is due to your clutch being worn (even though it's been like that for 8000 miles and we recon there's another 4-5000 or so left in it)
etc etc
Clearly all these excuses are laughable especially when you see the HUK doc states 01-04 and proves honda do know about the problem. These excuses were even repeated after giving them the HUK number to go and find (doubt they even bothered to look).
I'm still waiting for the response to my claim as I'm now out of warranty although having reported the problem well over 8 months ago and having it documented they'd damn well better fix it!
Personally I'd keep a print out in your pocket and see what they say, if they start saying they've never heard of any problems and start trying to fob you off then show them a copy.
You've managed better than I have so far, despite reporting the issue on multiple occasions I'm quite sure Honda haven't even bothered to change the gearbox oil!!!
What a completely useless company Honda have become.
By johnny 5
#1376366
hmm, sounds very fishy to me. Maybe its down to the member of staff who served you, or just the stinky attitude of certain dealers?
However, i found my dealer very friendly and willing to assist me with my problem. I have had nothing but an excellent service from my local dealer (Johnsons Honda, Slough, was served by Arun - Service advisor) and hope that my gearbox problem is properly diagnosed and corrected. This is my first ever visit though, but i didn't experience any problems whatsoever. I will let you know how i get on with the 'crunch'...
A print out of the bullitin will be happily brought along with me in my pocket :D
By johnny 5
#1377940
RESULT!!!
i took my motor down to Honda this morning, following up my problem with 2nd gear from last week, and as a result, they have agreed that the problem is due to a synchro cone (as stated in the bullitin report :P )
I did mention this when i brought my car into the garage though, i told them i have done a bit of research into this problem and have heard there is a bulletin released for it ;) this was noted down on the service sheet. Well done mr service assistant! :D
They have now put forward a claim under warranty for me, hopefully should all go through successfully! :D am i glad all my problems are sorted!! :D Just intime aswell, as my warranty expired on friday :? Cant wait, bring on the smooth (2nd) gearchanges! :D
The service i have received from my garage has been SUPERB, i highly recommend all people within Berkshire to use Johnsons honda in Slough, they have provided me the best trouble free service. Even though i am young too (being 23) they still treated me with respect and very professionally. I am so glad i got a Honda, as the service i used to receive from vauxhall garages (i used to own a vauxhall :oops: ) was appauling :evil: Well done Honda!
By Shonk
#1378194
insist that they replace the syncro on 2nd as well
as they dont do it with the fix unless you push for it
even though it has been worn out by the drag from 5-6
By undecided
#1397076
finally got them to do something about the problem and the car was booked in on monday, had a call back to say they've replaced the syncros on 5th and 6th gear only so I'm sure I'll still have problems but we'll see how it goes.
Apparently they managed to break some sort of clip or something when they got the gearbox out so I've got to wait until tomorrow for them to get the new part and get the car back together so they can test the fix, typical really.
Considering just how badly it's been crunching and grating trying to get it into 2nd gear for the last year or so I'd be amazed if the 2nd gear / 2nd gear syncro was fine but they seem to think it's ok :roll:
Don't expect it to be long before I'm back at the honda garage but at least they've done something I suppose. Knowing my luck it'll do nothing to 2nd gear and just make 5th and 6th difficult to select.
We'll see what happens.
By johnny 5
#1398184
Well my 5th and 6th synchos got replaced last week, seemed to have helped dramitically with my 2nd gear downshift problem! I get no crunch or notchyness anymore, but 5th and 6th gears feel a little stiff, as i would expect.
But before i took it in, i hardly got any crunching, just notchyness and unwilling to select 2nd gear, so maybe my 2nd gear synchro is ok and not damaged, well i hope not anyway...
however, i still got some juddering when trying to select 1st when the car is moving, but since i have a 2nd gear now thats not really an issue. It also pops out of 3rd sometimes when i shift up too, but at least my gearbox functions now, i guess im sorta happy... :D
By Shonk
#1400939
let the oil break in
and you will be grinding 2nd again
keep us informed how it goes mate
undecided wrote:finally got them to do something about the problem and the car was booked in on monday, had a call back to say they've replaced the syncros on 5th and 6th gear only so I'm sure I'll still have problems but we'll see how it goes.
By undecided
#1402683
Shonk wrote:let the oil break in
Didn't need to wait for the oil to 'break in', from the second I left the dealer it was crunching into second despite the fact they thought it was fine from a visual inspection.
It's a lot easier to get into 1st now which is good and only get the odd notchy gear change, before it wouldn't select 1st properly unless I was stationary or doing less than 2 miles an hour. Now I can select it when roling up to the lights as you'd expect (doing only say 6-7mph, very slow but couldn't get it in before at these speeds).
2nd gear as I said crunches badly almost every change but is much improved compaired to how it was, it does actually go into gear now which is great, just sounds nasty when doing so! Looks like 2nd gear syncro does need replacing as I suspected (all that grating and crunching unsupprisingly damaged it, unless it's the actual 'gear' that's now damaged of course?).
Seem to get a lot more 'spring loaded' gear changes though, from 2nd to third or third to fourth the gearstick springs out on the way to the next gear fairly often - only had this happen about 4 times in the last year but have had it 5 or 6 times in the last 100 miles since the service! Don't know what causes it but it is going into the next gear OK.
5th gear is a bit of an issue, it's a bit tight to get into when driving but not that bad, the problem is that from a standstill with the clutch all the way down it is IMPOSSIBLE to select 5th gear! Can get 1st, 2nd, 3rd, 4th and 6th fine but 5th isn't happening, it's as if it's locked out a bit like reverse when moving. Had no problems selecting it before the 'fix'.
6th is tight but can be selected ok when driving and when stationary.
Also seem to have gained a rather annoying rattle after the fix so maybe they haven't done a screw all the way up or something?
I've been aksed to do 200 miles in the car before bringing it back in to see if 5th / 6th loosen up etc, done about 120 now so will take it back for them to hopefully finish off the fix then.
I must say the service at Lincoln has drastically improved since the old service manager left so with any luck I'll actually get this resolved once and for all, seem to be moving in the right direction though which is good.
By Shonk
#1402794
5th and 6th will loosen up mate
takes much more than 200miles though
id worry about 2nd more
By undecided
#1402815
Shonk wrote:5th and 6th will loosen up mate
Yes, I'm more bothered about getting 2nd gear fixed properly as it still doesn't go into gear as smooth as it should.
5th gear is a major irritation though in that it can't be selected from a standstill, it certainly shouldn't do this and could cause issues in future.
If I ever come to sell the car for instance then I know the buyer is likely to try and select each gear before they go anywhere to see if they catch or crunch on the way in. At the moment second gear will greet them with a crunch and 5th has disappeared! They'd be walking away before they even started up the engine!
Don't plan to sell the car for quite a while but if I do I don't want all this hastle in the future - need to get it all fixed now.
  • 9
  • 10
  • 11
  • 12
  • 15
