lewisy wrote:I'm just thinking about purchasing a new type-r, has anyone experienced this problem on the 05 models ?I was under the impression that all 05 models were cured of this problem at swindon?
I could of course be wrong!
MickR wrote:after reading all the posts regarding this 2nd gear fix I'm still puzzled if my 05 CTR is suffering from the same problem.I have an 05 model and have a problem similar. Only when revving hard, but 1st to 2nd sounds like I missed the clutch slightly. Anybody else having similar problems?
i get a 'slight' clunk as i engage 2nd gear from 1st but only at very high revs & only occasionally ?
the engine is warm & it only seems to happen at 7k + revs.
my dealer looked into it & said that the 2nd gear fix he knew of was only for the early type-R's ? but i expressed my concerns so he agreed to seek advice from hondaUK.
one of the technicians apparently told him that its within normal tolerances for an occasional notchy change between 1st to 2nd when the engine is running at such high speeds ? he advised me not to push the car so hard in first gear !
i thought thats what a type-R was built for !!
cant help feeling i've been fobbed off...
Andymac wrote:The 1st to 2nd in mine sounds like I have missed the clutch slightly aswell ( a slight grind) but not when revving hard and it doesnt happen all the time. If i do the gear change slow and gentle it doesnt happen. My ctr is going to be looked at next week so will post what happens.
Andy
