Have a problem with your CTR? Tell us about them here...
By Greatbearminge2
#3653991
Hi guys.
I have an ep3 type r. It's covered 96k and had a new clutch fitted October last year. I went on a long trip over the weekend and its developed a sort of grinding noise from below the air box. When the clutch pedal is depressed it goes away but in neutral or in gear I can hear the noise. It's also started jumping out of 3rd on the way down and intermitantly wont go in on the way up...
Any ideas?
Last edited by Greatbearminge2 on Mon Jul 08, 2013 2:47 pm, edited 1 time in total.
By TheDon
#3698355
bondyboy wrote:The sound that goes away is your clutch release bearing
Common misconception - it is probably the gearbox input shaft bearing and the reason the sound goes away is you disengage the gearbox from the engine when you depress the clutch and the gearbox input shaft stops turning. If it was the clutch release bearing it would make the noise when you depress the clutch. Coupled with the other problem the recommendation that you get it looked at by a specialist is sound.
