- Fri Aug 07, 2015 8:50 pm
#3837377
So the results are in....my EP3 is slow! (but we already knew that! )
Speaking to Romain, from the off he said he wasn't a fan of the J's intake as he found it a little restrictive (a lot like the Mugen box) But there are only about 5 of these in the country so finding any information on other cars to find out performance using the box is hard.
I'm going to go with Romain's recommendation and change my intake to the Injen CAI with a Blox velocity stack and see if I can break the 230 mark!
I am a little disappointed that's all I made considering the mods I have and the advice I took onboard about avoiding buying cheap parts. But none the less, Romain has done a quality job with the map and the car does drive a lot better and the extra torque is noticeable.
Anyway I made 226 HP and 170(ish) Ft lb (can't see on the printout an exact figure?)
Mods wise next I want to get the whole car polybushed. Ill also try and underseal the car properly before winter.
Other than that I think I will save up for an LSD/gear ratio changes and maybe some drop in cams!
