OliMilanoRed wrote:Yeah I had vibrations and knocking. It was a bit of a ball ache to get to fit and sit properly. Had to take a hammer to a section of the pipe and bash it flat so it would fit properly. It bangs on your LCA's/Rear ARB a lot if you are lowered too far (I.E more than 30mm.) and just hates water. It takes while to settle in as well, a lot of the vibration I experienced went away after a month or so.
Thanks for the info dude, Yea mine is lowerd 30mm, which section did you hit with a hammer, It feels so wrong to do that to a brand new exhaust ,
When you say it was hard to get it to fit and sit properly do you mean that it's hard to get it to sit nicely in the center of the bumper?, my exhaust sits slightly to the left in the exhaust cut out, I wish I could get it centered, does yours sit to the left?
Many thanks
Sent from my SM-G935F using Tapatalk
