By *nub*
#3841053
I sold some semi slicks to someone in Spain that's all I remember! Yeah pretty sure it was you then, so many usernames in my head [emoji4]
By ADRi NH674P
#3846503
Not much to report yet.
Car is back with everything installed (a2 oil pump, baffled pan, injectors and reinforced valvetrain) except for the cams. Still waiting for the dyno.
Also, tired of my exedy stage 1 clutch shaking if not enough power given to start moving, i ended up swapping the oem clutch master cylinder for an oem honda civic em2 one. No more shaking. Now i can start moving on 1st gear just by clutch pedal releasing like oem clutch. Gear changes have also improved.
On the other hand, some minor changes that hopefuly will make the car handle better on track.
Before (full tank)
And after (3/4)
And of course, its new tyres for road use
By Simple Simon
#3846621
I presume when you had your car cover weighted you had a ballast in the drivers seat? (to replicate you sitting in the car)
Just wondering, as I came in at 1300kg on the dot with full interior, ballast and 1/2 a tank of fuel.
Can't tell from your pics wether the rear of your car is stripped out or not? Nice comparison either way.
By Lewisgame
#3846643
Simple Simon wrote:I presume when you had your car cover weighted you had a ballast in the drivers seat? (to replicate you sitting in the car)
That's about right. Mine came in at 1200kg. Basically full interior with A/C, half a tank of fuel, without driver. I weigh around 75-80kg (depending how many pies I've eaten) making it not far off 1300kg
By ADRi NH674P
#3846645
First picture (1260kg) was without me (just wanted to see how much car weighted).
Car has full interior (a/c, windows, seats, plastics, spare wheel, everything...) plus an audio system on the back.
And now you saying it, when I had the car cover weighted (second picture) yes, 75 kilos were placed on the driver seat. Only difference from first picture is a full exhaust system (headers & 3" exhaust). Maybe some kilos were shaved here, but that much? I will ask him again to make sure he used a ballast as there is quite a lot of difference between both pictures; but he is a reputable mechanic with more than 10 years working on ep3s so i'm sure he did it the right way. But now i'm curious about why there is so much difference in weight...
By ADRi NH674P
#3847054
Here are some pictures of my custom 3" Magnaflow exhaust I took yesterday.
And a random picture to see clearance between a 17x8 et33 rim and the rear arm (around 2cms)
By *nub*
#3847068
How loud is it mate, I see you scraped it already [emoji3]
What's that near the manifold collector, a small silencer ? Or a sports cat?
By ADRi NH674P
#3847083
*nub* wrote:How loud is it mate, I see you scraped it already [emoji3]
ADRi NH674P wrote:Today finally picked up the car after two weeks (for tomorrows trackdays as it's already paid) so it must be finished yes or yes...
Just got the headers and the exhaust done, nothing big. Still waiting for the cams, pump, pan, injectors etc to be installed and car tuned, but at least I can hear the engine sing again.
Here's a little clip.
I personally love it, plus it has its CE stamp for MOTs, etc so really happy with it.
Here are some more clips
Scrapped because of the speed bumps ("speed mountains" on my town). As it was custom made, exhaust sits pretty high for being 3".
What you see after the header is a 200cel Magnaflow cat.
By Simple Simon
#3847405
3" set up sounds nice! I find mine drones like crazy at cruising speeds (having it sorted soon) what's it like normal driving? Much louder than 2.5" for you?
Ah that clearance is nothing! I run 8.5J ET32! Haha
Just have to run a bit more camber for it not to touch. Lol
By ADRi NH674P
#3847407
These are 8J et33 with 2º of camber.
A friend of mine is running evo 8 wheels (8J et38) with 1º of camber and had issues with the clearance.
About the exhaust, it just drones at around 4k on uphills with light gas pedal. Can't really compare it with a 2,5" because the Toyosports spoon n1 replica didn't sound too loud.
By ADRi NH674P
#3849907
Saturday car was finally tuned on the dyno. As you don't know the dyno because I don't live on the UK, a stock FN2 made 204cv on it.
Here are the results:
You do not have the required permissions to view the files attached to this post.
By ADRi NH674P
#3858271
A little update as since I adopted a Spanish Greyhound on February I left the car a bit aside.
Got a trackday booked and paid on February 6th to test the new engine after its tunning, but unfortunately that day arrived my new four legs lovely partner, so prefered to go and receive it myself rather than sending another person.
So that last Sunday, I finally was able to try the car on track again, with all the new setups (engine and suspension)
Here's the result:
Temperature was unbearable, 36º air temperature, with oem water radiator (plus ac radiator at the front...). At least the oil radiator kept oil temperatures down, but water was literally boiling (check engine appeared four times)
Need to find a gap and install the Tegiwa water radiator I received some months ago, otherwise next time I could break something...
By ADRi NH674P
#3861127
Last Saturday tracked the car again, that time on slicks (was my first time ever on slicks).
Really enjoied the car a LOT!
On some corners I noticed a bit of understeering so next time will try to "play" with the suspension settings to see if I can improve the handling a bit more.
By *nub*
#3861211
You're a sh-t driver
Added in 23 seconds:
Jokes [emoji846][emoji1303][emoji8]
