By jonezy
#3625136
samco77on wrote:I have used a new standalone ecu that we are a dealer for. Called an emu. It is a very advanced ecu for the money. I will put more up about it later.
The pops and bangs are a launch control limiter.
Thanks Ben.
just hitting the lauch limiter then? nothing to do with launch control fuel enrichment then?
By samco77on
#3625154
Thanks Ben.
I've set the launch control to be on all the time, so whenever the speed is below 15km/h its limited to 4800rpm. Yes there is an enrichment for launch control, but the main cause of the bang is the ignition cut. I haven't actually used it to launch yet. i'm a bit worried about my driveshafts as it makes 10psi of boost sat on launch control.
By leetec
#3625354
samco77on wrote:[quote="jonezy
Thanks Ben.
I've set the launch control to be on all the time, so whenever the speed is below 15km/h its limited to 4800rpm. Yes there is an enrichment for launch control, but the main cause of the bang is the ignition cut. I haven't actually used it to launch yet. i'm a bit worried about my driveshafts as it makes 10psi of boost sat on launch control.[/quote]
your drive shafts should be fine. I'm still running standard shafts and iv been launching on drag slicks at the pod.
By jonezy
#3630954
hey sam,
did you have to do anything to the throwout arm on the comp clutch? did you out a washer under it or did you bleed it by removing the slave cylinder?
its the stuff in here im talking about if you havmt seen it? im just a bit concerned about the fitment.
http://civictype-r.co.uk/forum/viewtopi ... 3&t=221745 - worth a read if you havnt seen it. they may have fixed the problems now though
assume yours works well with a good pedal and selects all gears great?
just curious as i plan on fitting mine myself
cars looks great btw, cant wait to start fitting my turbo
thanks
By jonezy
#3631135
samco77on wrote:No I didn't have any problems with it. Fitted mint. Feels nice and does its job. Didn't even see any of that until now.
seems a wierd old carry on.
so you just fitted and bled the slave?
By jonezy
#3631579
samco77on wrote:I didn't even bleed It at first. Just unbolted the slave when I took the box out. It worked when I put it back in. Then I bled it as a precaution. Works mint.
nice one. hopefully mine will work that easy lol
