By Eric_Sn@il
#3829838
fronts all on, much caster!
rears all built up
All fitted and wound all the way down, confusing as i thought id have issues with the rear sitting high :/
So ordering some shorter mains springs when bilstein get back to me with the spring rates of the current ones
By Eric_Sn@il
#3830253
New springs arrived - Image Same poundage just 30mm shorter
Sits so much better - Image
Just need to sort the rear out height wise and get it sitting level on each axle and we are good Image
Unfortunately another side affect of these coilovers means i've run out of adjustment on my track rod ends, so new adjustable ones on the way, get them fitted, bleed the brakes again and make the new splitter it should be perfect again!
By Eric_Sn@il
#3830256
Hoping i can get the steering arms out this time without dismantling the whole car again :bigcry:
By Eric_Sn@il
#3830265
Even easier with no turbo and boost pipes in the way too :lol:
By Eric_Sn@il
#3830711
Arms out ready for new ones arriving, needed to 'adapt' the spanner slightly to avoid removing the rack
By Eric_Sn@il
#3832726
First drive out in near on a year!
By Eric_Sn@il
#3833558
Proper carbon fuel pump cover fitted
Got a quote for the exhaust sorting that im happy with so will get that sorted soon and get the rest of the diffuser fitted :D
By Eric_Sn@il
#3834561
Had a small brake fluid leak ever since re-furbing the AP's, replaced the bleed nipples as it thought it was them. Still doing it, noticed this today -
Awesome, ordered some replacements. Should be here tomorrow
By Eric_Sn@il
#3835560
Cars a bit heavier than i thought!
By Eric_Sn@il
#3835893
New wings fitted -
Need some spacers fitting now!
By Eric_Sn@il
#3836565
Couple of pics from the weekend -
Need to fill in the holes from the old splitter, also removing the canards. not sure they suit it any more
By Eric_Sn@il
#3837529
Set about fitting the new wings this weekend with the help of a mate, decided to paint the underside of the front arches just to protect them -
All fitted along with the spacers -
Bit wider now -
Noticed this cleaning it after :'( -
Going to have to buy a heated screen i think.
Couple of pictures from a local show/meet at the weekend -
By cammy92
#3837585
I like those wings, suit it sooooooo much
By Eric_Sn@il
#3838209
So finally had the exhaust made, and got the rest of the diffuser fitted -
How it looks with no diffuser on -
Bit of a miss communication between me and exhaust builder, i wanted the tip cut flush with the bottom of the diffuser so you couldnt see the exhaust tip at all. So left it as it is for now see if grows on me, if it doesn't ill whip the angle grinder out and flush it off :)
Picture of it from Japfest2 -
  • 64
  • 65
  • 66
  • 67
  • 68
  • 70
