By Lewisgame
#3860753
Eric_Sn@il wrote: Got a set of these coming too -
which mount like this -
I need these! Look perfect for brake cooling. My brake cooling is just feeding the inner wheel arch with cold air.
By Eric_Sn@il
#3860791
Give BYC a shout mate :)
By Eric_Sn@il
#3863347
So notice i didn't have much thread on my wheel nuts randomly one afternoon
Chucked in some ARP extended studs
Much better!
Also shortened the wiper arms so they just clear the screen rather than the sun strip :)
Got sick of the seat rails moving around slightly, so lobbed them out
New rails all fitted
Bought a new heater and blower to replace the bulky stock heater and the aftermarket blower as it was as much use as an asthmatic mouse
Dash removed to fit it -
Mounts in -
Rubber spacers to stop vibrations -
Heaters fitted
Started removing all the crap -
Having this lot wired in, and removing the steering wheel stalks -
Bought a new rear anti roll bar, similar set up to the BTCC cars of the day, equivilant to a 32mm one 8)
Cleaned up the underside while it was all off
All fitted -
While i was doing that i bought some hardrace spherical camber arms -
these also have some spacers above them, i read a documentation that a man much clevererer than me analysed the suspension set up on the EP. And this was a recommendation, done to get more static camber and make the camber curve on compression more linear. Not sure if it will actually work, but will see
while that was all off i took the opportunity to upgrade the bushes and clean up the top mounts on the rear suspension
Cut out the remaining interior pieces -
Bought some covers for the windows, no more sneaky hands inside my car
By Eric_Sn@il
#3863352
civvycivvy wrote:Serious car. What rear anti roll bar is that?
Custom Area Motorsport one
By Eric_Sn@il
#3864350
Heaters and ducting all plumbed in -
Car got taken up to PDA Paul to have the new wiring loom made, should save over 20kg in wiring when its all done and finished :o -
Made a new dash panel in prep for the wiring doing -
Steering wheel controls all mounted -
Once the cars back i can get these all fitted, helmet hammock, New tow hooks for front and rear, and finally a spark plug cover, havent run one for years lol!
  • 66
  • 67
  • 68
  • 69
  • 70
