- Fri May 06, 2016 7:33 am
#3855643
Just saw this on your Instagram, shame to see that much metal in the gearbox, atleast you can say the magnetic plug works
Eric_Sn@il wrote:not a thing. cars I pulled the splitter off to check for the exhaust noise. then noticed the leak! still drives perfectThat's strange considering the damage! Let's hope there's no bad damage to inside the box.
Delboy23 wrote:No more than normal, think its 90psi on my gauge.Eric_Sn@il wrote:not a thing. cars I pulled the splitter off to check for the exhaust noise. then noticed the leak! still drives perfectThat's strange considering the damage! Let's hope there's no bad damage to inside the box.
What oil pressure would you see on track on your car?
Eric_Sn@il wrote:6 bar or so? What is your sender tapped into then? I don't see half that pressure on track.Delboy23 wrote:No more than normal, think its 90psi on my gauge.Eric_Sn@il wrote:not a thing. cars I pulled the splitter off to check for the exhaust noise. then noticed the leak! still drives perfectThat's strange considering the damage! Let's hope there's no bad damage to inside the box.
So yeah...
Box is toast
Well, not quite that bad, the diff and final drive can be saved, but the casing is dead.
New one of those is sorted, getting new synchros fitted along with seals and bearings etc.
Diff is also getting pulled apart and double checked over. So its not as bad as it could have been but its still expensive :'(
Delboy23 wrote:roughly yeah, its mounted on the sandwich plate in between the oil filter from what i remember.Eric_Sn@il wrote:6 bar or so? What is your sender tapped into then? I don't see half that pressure on track.Delboy23 wrote:No more than normal, think its 90psi on my gauge.Eric_Sn@il wrote:not a thing. cars I pulled the splitter off to check for the exhaust noise. then noticed the leak! still drives perfectThat's strange considering the damage! Let's hope there's no bad damage to inside the box.
So yeah...
Box is toast
Shame about the box, looks nasty. What actually let go?
Delboy23 wrote:That's a clutchmasters 400 isn't it?? I've the same :SNo idea, its a stage 4 6 puck one.
What mileage was on it buddy?
Delboy23 wrote:Which setup will you go for now?Going for a competition clutch twin plate i think
Rotten luck that.
jonezy wrote:As much as I would love one of these, you not worried about the slave cylinder having to push that?In what way?
Lewisgame wrote:Interesting with the gearbox oil cooler. I take it the fittings just go in place of the drain and fill plugs?The do indeed.
Do you think the gearbox is overheating causing you issues?
ADRi NH674P wrote:Usually you need to drill new holes.Running it off the drain and fill holes.
All gearboxes overheat, specially on track, but nobody knows because nobody runs a gearbox temperature gauge.
One of the best upgrades if you track your car.
