Thanks for the replies, and sorry about the delay on updating the thread. I have been messing with the car over the last few days so haven't had time to post pics.
While the engine was being run in it was time to sort out how to boost it. I bought a Rotrex top-mount charger kit from TTS, and when I finally got all the bits I was ready to try it out on my spare engine. This is the C30-94 charger, the medium sized one. I would have liked to have used the larger charger, but there was just not enough space, and the medium one took enough work to squeeze in as it was. Never mind, it was a compromise I was willing to take to keep the aircon.
The kit is designed to be fitted like this:
Its designed for a top mount intercooler and bonet scoop. IMO bonnet scoops on CTRs should be for track cars and the Max Power crowd only, so a few changes were needed.
I want to run it like this:
so with a bit of pipe work I can plumb it into a charge cooler located over the gearbox. The problem is that there was not enough clearance between charger and fuel rail, so a bit of tweaking was needed to get it to fit, which took a few weeks of precise drilling and filing.
I bought an AEM fuel rail, but this was way too big to fit, so I sold it on the forum. The stock rail is good enough for my power needs, but I removed the fuel rail damper, drilled it and tapped it to fit a AN ORB connector for a fuel return line.
Not as pretty as the AEM, but it will do the job. In the US they have gone up to 500whp with this setup, so it should be fine for my build.
Fuel rail damper removed, drilled and tapped to fit a -6AN ORB connector. With a 90degree hose end on the return line I had no problem plumbing this in.
Some more essentials for the fuel system:
Walbro high pressure in tank fuel pump.
Bosch 044 inline fuel pump. A common motorsport pump. I also bought some mounting brackets.
Aeromotive fuel filter.
Aeromotive fuel pressure regulator and pressure guage.
Enough hose and fittings for a new fuel line and to plumb in the existing fuel line as a return line.
Fire extinguisher in case my fuel system mods go wrong!
