Little update;
M Factory Helical LSD now here with bearings and plugs.
Can't wait to get it fitted!
Then - 314BHP JRSC'd Milano Premier EP3
hovblackctr wrote:Maxsports should be fine mate!Cheers fella!
What compound and size are you going for?
nathanpar wrote:I know mate was very chuffed to say the least. I may purchase one come MOT time and when I need a sports cat..Awesome to get that reading without a Rbc dude, Will be interesting to see what you end up with when you purchase one. "if" Very tidy car!!!
dannyhall wrote:What cat are you running on the mani atm? I'm guessing emissions are way to high otherwise.hovblackctr wrote:Maxsports should be fine mate!Cheers fella!
Going for 215/45/17 in a Medium compound, unless a softer compound is recommended?
Thanks mate
nathanpar wrote:What cat are you running on the mani atm? I'm guessing emissions are way to high otherwise.Decat fella, sports cat come next MOT time... Would imagine the numbers to be lower when I get a cat in there
r8byb wrote:That should work really well, how have you secured the bar? :cooldude:Two holes drilled either side, headrest slots straight through it keeps it sturdy. Simple solution stolen off the forum!
dannyhall wrote:Sounds sturdy enough! I need to find a way of stopping wind noise on my go pro!r8byb wrote:That should work really well, how have you secured the bar? :cooldude:Two holes drilled either side, headrest slots straight through it keeps it sturdy. Simple solution stolen off the forum!
r8byb wrote:Dont film from outside the car? Get a harness bar and mount it on there?dannyhall wrote:Sounds sturdy enough! I need to find a way of stopping wind noise on my go pro!r8byb wrote:That should work really well, how have you secured the bar? :cooldude:Two holes drilled either side, headrest slots straight through it keeps it sturdy. Simple solution stolen off the forum!
dannyhall wrote:That would stop it yesr8byb wrote:Dont film from outside the car? Get a harness bar and mount it on there?dannyhall wrote:Sounds sturdy enough! I need to find a way of stopping wind noise on my go pro!r8byb wrote:That should work really well, how have you secured the bar? :cooldude:Two holes drilled either side, headrest slots straight through it keeps it sturdy. Simple solution stolen off the forum!
r8byb wrote:That would stop it yesHaha!
I may well have a cage to mount it on shortly
