ctr-lib wrote:Did you not fancy going down drivers side with oil cooler hoses? Much easier than passenger side only hard bit it notching bodywork below headlight.Initially I was going to run them down the drivers side. But the fittings I got with the kit (Tegiwa) I wasn't happy how the pipes would route. It's tighter than you think trying to mount the thermostatic plate
I like what you've done with the bottom bracket for the oil cooler looks really neat.
I wasn't happy with just having the cooler hanging from the crash bar. It wasn't very secure and I thought it could rub on the AC rad and bumper eventually causing damage and possible an oil leak. Now it's totally solid and not touching anything else so hopefully should last.
Build thread
