Its Whats Inside That Counts...
By Collister
#3848488
Hi
Im currently sorting a roll cage and racing spec seat mounts.
the problem is I need to drive the car to SW for the install, is it easy enough to bolt my seats straight to the floor or side mounts without additional brackets etc?
By Z650
#3849728
The floor pan on an Ep3 is uneven and you can't even fit standard bucket seat side mounts to it without cutting, you need to buy specific seat mounts for an EP3, I think mine are Tegiwa. So to answer your question, can you mount bucket seats to the car floor without mounts?, 'no'.
Best bet would be to drive it with driver's standard seat still fitted and remove it once you get there. It is only four bolts to remove and then unclip the seatbelt sensor under the driver's seat so a ten minute job.
