By Aid1987
#3059175
T180985 wrote:would probably save 35-40kg with that lot! pretty good really, im struggling to save 1-2kg here and there at the moment :lol:
That much?! Well that's good, I might give it a go then. :-D
How much weight have you stripped in total?
By T180985
#3059196
when i last had the car weighed it was 1156Kg with full tank of fuel & 35-40kg roll cage (its about 1250kg stock, a/c model) so ive removed a good 140kg so far! but ive since had the air con removed, plastic windows fitted and a few other bits done so im hoping to get the car down to 1100kg
By Eric_Sn@il
#3059197
T180985 wrote:when i last had the car weighed it was 1156Kg with full tank of fuel & 35-40kg roll cage (its about 1250kg stock, a/c model) so ive removed a good 100kg so far! but ive since had the air con removed, plastic windows fitted and a few other bits done so im hoping to get the car down to 1100kg
mine should be down to around 1000kgs with minimal fuel in come april :WOOT
By T180985
#3059212
:bad-words: damn you! still lots more work to be done then :lol:
will be stalking your build thread from now on :-D
By Eric_Sn@il
#3059215
:lol:
ABS is the next big thing to get chopped out :bigthumb:
By T180985
#3059241
i heard the ABS was only worth 4kg, can you post up how much it weighs once its out please?
next for me is to remove the front widows glass to replace with plastic windows so i can then remove all the electric window stuff :bigthumb: and removing the rear crash bar
By Eric_Sn@il
#3059303
T180985 wrote:i heard the ABS was only worth 4kg, can you post up how much it weighs once its out please?
cant see that mate, the ABS pump itself maybe, but then you have all the brake lines and ABS sensors etc, will soon add up to a fair old chunk i recon
plus it gives me the space to relocate my oil filter to the space
By mc36155
#3071167
is the 1204kg for the ep3 accurate? does that include air con?
By pulpmelon_r
#3185644
Not sure if this has been covered but:
I bet a stainless race header with decat knocks a few kg's off over the cast jobby
Also my coilovers were much lighter than the springs and shocks.
By T180985
#3187428
pulpmelon_r wrote:Not sure if this has been covered but:
good point, if you have any you can weigh feel free to get the numbers over to me and i will add them to the list :salut:
By gearinator
#3187440
T180985 wrote:As we have had a few threads on how to loose weight from the EP3 i thought i would put a list together of how much everything weighs while im in the process of stripping my interior. ive weighed alot of items but Some items are estimates and ive taken some figures from other threads so if you would like to add/ammend anything from the list please let me know :thumbup:
I will try add the weights of replacement items directly bellow OEM aswell
Exterior
OEM Bonnet - Kg
(Sound Deadening - Kg)
> Carbon Seibon Bonnet - 4Kg approx
Under bonnet wing / flitch covers (facelift only) - .082Kg each
OEM Rear Hatch (Exc Glass) - 17kg
> Carbon Rear Hatch - 7Kg
OEM Rear Glass - 5kg
>Perspex Window - 2.5kg
OEM Front Windows
> Lexan window 1.8kg each
OEM Side Rear Windows - 3.6Kg Each
> Perspex Window - 800g each
Front Fog Lights - Kg
Oem Alloy with 205/45/17 - 21.5Kg
>Rota Torque with 215/45/17 Toyo R888 - 18.5Kg
Wing Mirror trims - 0.034kg
Interior
Front Seatbelts - 3.5Kg Each
>6Point Harness - Kg
Rear Seatbelts - 2Kg Each
Misc Seatbelt parts - 2.6Kg
Side rear plastics - 3.25Kg Each
Rear Speakers - 0.156Kg Each
Rear Speaker Covers - 0.2Kg
C Pillar Plastics - 0.322Kg Each
Remaining Plastics in boot (exc hatch) - 2.05Kg
Bottom Hatch Plastics inc Sound Deadening - 1.4kg
Rear wiper motor - 0.9kg
Rear wiper arm - 0.166Kg
left / right hatch trim 0.216kg
Parcel Shelf 1.815kg
Boot Carpet - 1.8Kg
B Pillar Plasitcs - 0.4Kg Each
B Pillar Floor Plastics - 0.295Kg Each
Rear Seat Back (both sides) - 17.1kg
Rear Seat bench - 4.5kg
Rear headrests - 0.548kg
Front Seats - 25Kg Each Approx
>Bucket Seats - 10Kg Each
Front Carpets, Floor sound proofing, Handbrake plastics inc cup holders etc - 11Kg Approx
Silver gearknob garnish (lower dash facia) - 0.088Kg
Roof inc sound Deadening - Kg
Under dash fuse box cover, inc white cushion - 0.232Kg
Sound Deadening Behind Dash - 10 Kg Approx
Interior Heating System - Kg
Front Door Cards - 4Kg
Passenger Airbag - 6.6Kg
Steering Wheel - Kg
Other & Modifications
Spare Wheel - 11Kg
Tool Kit + sw bolt - 2.2Kg
Standard Battery - 15Kg Approx
>Race Battery - 5.7Kg
Air Conditioning system - 18Kg
Front Crash Bar - 7Kg
Rear Crash Bar - 7Kg
CPL Racing Oil Cooler Kit - 3.3Kg
OEM Front Calipers inc bolts etc - 4.5Kg each
>Stoptech BBK 328mm 2 piece disc - 22Kg
>TGM Brembo Calipers - 6Kg
>TGM Brembo 330mm 1 Piece disk - 8.5Kg Each
>TGM Brembo 2 Piece disk - Kg Each
So if you remove that lot and with a single front bucket Seat you could be heading towards over a 200Kg weight loss :shock:
Would like to say a big thanks to everyone thats contributed to the list :salut:
By gearinator
#3192264
T180985 wrote:quick update.... by installing front lexan windows & removing the motors etc you save approx 8-10kg :bigthumb:
Lexan being plastic I'm assuming ??
By T180985
#3192475
yes mate :bigthumb:
