- Sat Feb 26, 2011 4:11 pm
#2879425
As we have had a few threads on how to loose weight from the EP3 i thought i would put a list together of how much everything weighs while im in the process of stripping my interior. ive weighed alot of items but Some items are estimates and ive taken some figures from other threads so if you would like to add/ammend anything from the list please let me know :thumbup:
I will try add the weights of replacement items directly bellow OEM aswell
Exterior
OEM Bonnet - Kg
(Sound Deadening - Kg)
> Carbon Seibon Bonnet - 4Kg approx
Under bonnet wing / flitch covers (facelift only) - .082Kg each
OEM Rear Hatch (Exc Glass) - 17kg
> Carbon Rear Hatch - 7Kg
OEM Rear Glass - 5kg
>Perspex Window - 2.5kg
OEM Front Windows
> Lexan window 1.8kg each
OEM Side Rear Windows - 3.6Kg Each
> Perspex Window - 800g each
Front Fog Lights - Kg
Oem Alloy with 205/45/17 - 21.5Kg
>Rota Torque with 215/45/17 Toyo R888 - 18.5Kg
Wing Mirror trims - 0.034kg
Rear wiper motor alone - 900g (0.9Kg)
Rear wiper arm alone - 166g (0.2Kg)
Yellow speed track spec front coilovers 6.7kg each, rear 2.7kg each
Interior
Front Seatbelts - 3.5Kg Each
>6Point Harness - Kg
Rear Seatbelts - 2Kg Each
Misc Seatbelt parts - 2.6Kg
Side rear plastics - 3.25Kg Each
Rear Speakers - 0.156Kg Each
Rear Speaker Covers - 0.2Kg
C Pillar Plastics - 0.322Kg Each
Remaining Plastics in boot (exc hatch) - 2.05Kg
Bottom Hatch Plastics inc Sound Deadening - 1.4kg
Rear wiper motor - 0.9kg
Rear wiper arm - 0.166Kg
left / right hatch trim 0.216kg
Parcel Shelf 1.815kg
Boot Carpet - 1.8Kg
B Pillar Plasitcs - 0.4Kg Each
B Pillar Floor Plastics - 0.295Kg Each
Rear Seat Back (both sides) - 17.1kg
Rear Seat bench - 4.5kg
Rear headrests - 0.548kg
Front Seats - 25Kg Each Approx
>Bucket Seats - 15Kg Each
Front Carpets, Floor sound proofing, Handbrake plastics inc cup holders etc - 11Kg Approx
Silver gearknob garnish (lower dash facia) - 0.088Kg
Roof inc sound Deadening - Kg
Under dash fuse box cover, inc white cushion - 0.232Kg
Sound Deadening Behind Dash - 10 Kg Approx
Interior Heating System - Kg
Front Door Cards - 4Kg
Passenger Airbag - 6.6Kg
Steering Wheel - Kg
Interior condenser rad and pipes - 1765g (1.75Kg)
Air-con pump alone - 5685g (5.8Kg)
All Air-con pipe work, brackets, and bolts - 845g (0.85Kg)
EPS control unit - 835g (0.83Kg)
Air-con condenser fan - 1800g (1.8Kg)
Air-con main condenser rad - 1900 (1.9Kg)
Glove box - 870g (0.9Kg)
Pair of facelift fog lights - 808g (0.8Kg)
Pair of front metal bumper brackets / crumple plates? - 366g (0.3Kg)
Mark Beesly carbon bonnet, 4.3 kg
Other & Modifications
Spare Wheel - 11Kg
Tool Kit + sw bolt - 2.2Kg
Standard Battery - 15Kg Approx
>Race Battery - 5.7Kg
Air Conditioning system - 18Kg
Front Crash Bar - 7Kg
Rear Crash Bar - 7Kg
CPL Racing Oil Cooler Kit - 3.3Kg
OEM Front Calipers inc bolts etc - 5.35kg each
OEM Front Disks - 7kg each
>Stoptech BBK 328mm 2 piece disc - 22Kg
>TGM Brembo Calipers - 6Kg
>TGM Brembo 330mm 1 Piece disk - 8.5Kg Each
>TGM Brembo 2 Piece disk - Kg Each
Super Unleaded - 15Kg per 20 Litres
So if you remove that lot and with a single front bucket Seat you could be heading towards over a 200Kg weight loss
Would like to say a big thanks to everyone thats contributed to the list :salut:
Exterior
OEM Bonnet - Kg
OEM Front Windows
Interior
>6Point Harness - Kg
Boot Carpet - 1.8Kg
Steering Wheel - Kg
Spare Wheel - 11Kg
