Plantie wrote:Can this be put in the Hazard indicator switch hole? i.e. swap to drivers side???? Hole does look smaller mind....
With a bit of work yes.
The hazard switch is mounted on a moulding at the back of that hole with the switch pushing inside the fascia hole to activate the switch.
Whereas the ciggy adapter was secured in the hole, and the element was then used inside this part of the adapter.
There is a lot of work, mucking about with putting it in the hazard hole and then mounting the hazard on the other side will cause numerous problems.
Best alternative, order a left hand drive fascia and it will be perfect.
SIGNATURE PICTURE REMOVED BY MODS. TEXT ONLY PLEASE.
