#2875731
Has anyone still got the guide on how to fix this? the link is dead!! i am planning on fixing it next to the steering wheel!
if anyone who has done this before, and is somewhat local to Milton Keynes, or in Birmingham/Leicester as i am sometimes over there, let me know if you wouldnt mind lending a hand or doing it and i will sort you out some beer money :thumbup:
Med
#3732286
http://www.ebay.co.uk/itm/S2000-RED-ENG ... 2a21a03f13
I got this came with instructions, but was simple as only solder two wires to two existing wires under the steering wheel and wrap well with electrical tape, took about 45 mins. Not sure it's a oem button though as it lights up :eek: but it looks okay. Finally add the earth. I used plastic and shaped using a dremmel to fit by steering wheel. Vinyl wrapped it to give it cf effect.
http://i552.photobucket.com/albums/jj35 ... 643239.jpg
#3740689
Nice installation Ryansss. The stock start buttons are illuminated. I was thinking about installing mine in that location but I kinda want to show it off so I want to completely remove the section where the key goes and install the button there so I can basically have the button exactly where the key would go. Mine is a rally car so I am going to eliminate the use of the key anyway.
