#1836070
refurb your own take about 20mins all you want is some 1500 wet n dry a 8mm threaded rod or a bolt and a drill, spin the gear nob in the drill using the threaded rod to hold it, apply the wet n dry with water to remove the scratches then either lacquer or better still autosol looks loads better and does not chip and scratch like lacquer
#1836234
rickhondar wrote:refurb your own take about 20mins all you want is some 1500 wet n dry a 8mm threaded rod or a bolt and a drill, spin the gear nob in the drill using the threaded rod to hold it, apply the wet n dry with water to remove the scratches then either lacquer or better still autosol looks loads better and does not chip and scratch like lacquer
THREAD CRAPPIN dude?? im sure those who r able to do there own will do, for others who either dont have time or the ability then.......... :salut:
#1836277
thats a matter of opinion :badrazz:
#1836285
Jackster1 wrote:£20 is an absolute bargain for this, the quality of work is 100% - I don't believe you'll get anywhere near the finish trying this yourself................
you can i have done it, the gear knob was like glass, how do you think he does it :scratch:
#1836291
This is the same reason people buy salad leaves in bags, or pre chopped broccoli............... :wink:
#1836308
Ok - I was just trying to stand up for the chap really.......well hey - I was happy to pay £20, I just thought to put a thread on saying actually you can do this yourself was a little unfair when Brens is just offering a refurb service, maybe the DIY version should have been put in the How to section rather than this thread?
#1836373
Jackster1 wrote:Ok - I was just trying to stand up for the chap really.......well hey - I was happy to pay £20, I just thought to put a thread on saying actually you can do this yourself was a little unfair when Brens is just offering a refurb service, maybe the DIY version should have been put in the How to section rather than this thread?
nothing against Bren just saying how easy it is also put a more detailed how to guide up
http://www.civictype-r.co.uk/forum/post ... &p=1836191
as for DIY bren will do it very similar maybe he has access to a lathe but drill does the same thing
#1836399
indeed it is so keep yours to yourself :badrazz:
#1836407
Are you and Bren Lovers? :scratch:
I WILL EXPRESS MY OPINION IF I WANT :stfu:
