tp wrote:Dyno run was done in 5th by the looks of it and at the wrong ratio correction factor.Ahh, was wondering what that correction factor was. Can't say what gear they did the run in though as we weren't allowed to stand around the cars.
Jon
JonCTR wrote:Yes, its an upgrade to the normal ecu.Thanks for the info buddy. From your experiance/knowledge what the best setting for a standard CTR with just KPro mod done?
Yes, it has two limiters. The usual upper limiter which you can set to whatever you want, and a launch limiter, where if the car is doing less than about 2mph, it will limit to what you set it at. Most people have the launch limiter set to about 3,500 - 4,000 rpm.
As soon as the car starts moving, the launch limiter no longer functions.
Jon
JonCTR wrote:The standard Hondata reflash raises the upper limit to 8,600rpm from 8,100 or 8,250 rpm so that should be fine. The k-pro maps that come from Hondata are set to 8,600 rpm. Thats the highest Hondata recommend on stock valve springs.Thank you for your advise mate! PS how much is it or have you got a web link?
As for the launch limit, I haven't had mine on the 1/4 mile at Pod yet, but most seem to use between 3,500 and 4,000 rpm dependent on how much grip there is.
I've only had my k-pro for about 6 weeks, so am still learning myself.
Jon
JonCTR wrote:Have a look here for the UK dealers ;Thanks again mate, you've been a great help! :thumbup: I know who to speak to for more advice!!!
http://www.civictype-r.co.uk/forum/vie ... hp?t=39655
I upgraded from the reflash so it was around £400. Price without upgrade is approx £730. All UK dealers are the same price, but worth confirming, as I might be wrong.
Jon
supercharged_civic_type-r wrote:hi, does anyone know how to switch the lambda sensor off via K-pro? my engine light is perminently on. URGENT REPLY NEEDEDMisc tab in the parameters windows, uncheck the OBDII enabled box
Many thanks
Mark
MJB_TYPE_R wrote:I've been reading the KPro threads with interest but can anyone tell me if this affects the standard warranty at all please?Basically say goodbye to your engine warranty, and hello to a potential £6k bill from Honda if your engine goes pop. I watch the oil levels like a hawk now as I still have about 11 months warranty left.
JonCTR wrote:Latest dyno, same spec as last time but now with DC sports race header.8)
Not too shabby, 10 wheel bhp / 13 fly bhp up on the decat pipe
