Im planning on doing a few trackdays next year so thought it might be a good addition?
http://www.tegiwaimports.com/select-...indicator.html
Ep3 facelift Satin Silver JRSC Hillclimb Car
E36 325I Drift Car
Lewisgame wrote:There's a few people on here that use them. Also, if you go K100/KPRO they can add a shift light to one of the lights on the dash. I have the EML come on as a shift light.cheers is it not a bit disconcerting for a while when the engine light flashes must be like driving a VW
ADRi NH674P wrote:I installed mine two weeks ago.are they easy enough to fit and set up?
Does the job.
Collister wrote:cheers is it not a bit disconcerting for a while when the engine light flashes must be like driving a VWLewisgame wrote:There's a few people on here that use them. Also, if you go K100/KPRO they can add a shift light to one of the lights on the dash. I have the EML come on as a shift light.
Collister wrote:are they easy enough to fit and set up?Two wires to the cluster loom and the other one to -
ADRi NH674P wrote:Doesn't sound too bad thenCollister wrote:are they easy enough to fit and set up?Two wires to the cluster loom and the other one to -
Setting it up is really easy too (https://ecliptech.com.au/wp-content/upl ... manual.pdf)
