Mind Over Matter...
By phil54
#3846337
Hi last week one of my rev counter bulbs went.
I replaced it today, and checked all the other ones were tight,I also took the white cover of the back.
However when I put it all back together the bulbs for the speedo were not lit.
Took it apart again and checked the 2 multi plugs were tight and the bulbs were tight.
Turned the lights on and one side of the speedo was lit up and the other side was still out.
I tapped the speedo clock and it lit up.
Put it back together and went a drive and everything was lit up.
Turned the lights of and when i put them on the same problem occurred.
Tap the top of the dash and it lights up again.
The speedo clock seems to remain lit when driving unless you turn the lights of then back on again.
Any help would be appreciated,thanks
