I've been following this:
1) Turn the ignition switch ON (ll).
2) Press the “LOCK” or “UNLOCK” button on one of the transmitters. (A non-programmed transmitter can be used for this step.)
3) Turn the ignition switch OFF (0).
4) Repeat steps 1, 2 and 3 two more times with the transmitter used in step 2.
5) Turn the ignition switch ON (ll).
6) Press the “LOCK” or “UNLOCK” button on the same transmitter. Check that the power door locks cycle to confirm that you are in the programming mode.
7) Press the “LOCK” or “UNLOCK” button on each transmitter. (You can program up to four transmitters per vehicle.) Check that the power door locks cycle after you push each transmitter button, confirming that the system has accepted the transmitters code.
Everything works up to a point. I do the steps to get into programming mode and then I press the lock button again to program the fob to the car and everything clunks as it should but when I remove the key and press the lock and unlock buttons nothing happens. The light on the fob flashes but the car doesn't lock.
Am I doing something wrong here? (probably)
Thanks.
