Mind Over Matter...
By Aaron Coady
#1876516
I think I remember 'evilowl' posting up a thread with direct links to an American website where they contain lots of different calibrations for K-Pro. I cannot seem to find it using the search function...... Even though I'm typing the same thing as I did a few months ago ... :scratch:
Anyone remember it? and if so, do you have the link?
By cheety
#1903631
thats all well and good, but most of them are tuned for 94RON fuel....will this affect anything??
By evilowl
#1903788
The RON measurements in the US are not comparable to the UK
Our 95 ron is the equivalent of their 91, our 98 is the equivalent of their 94
By SR-25
#1906448
I'm trying to find the application that goes on your laptop. I brought the car with Kpro already on.
By ep3petey
#2036357
I had a try at uploading on of the maps that the RSX boys had uploaded that best matched my mods, to my K-pro and set the mil light to come on if knock is detected.
Mil light came on after a few seconds just on tick over, so removed that map and just stuck to the "tunned ep3" map.
Not sure what I need to do get it right, apart from getting my car set up correctly on RR.
Would be nice if I could find something to suit in the mean while though!! :scratch:
By LeeH
#2036372
If you don't know what you are doing leave it alone! I've seen first hand the results of a 'little knowledge'
A little knowledge is dangerous...and it applies all too well here :roll:
By ep3petey
#2036422
LeeH wrote:If you don't know what you are doing leave it alone! I've seen first hand the results of a 'little knowledge'
I have knowlage of engines, but not in engine mapping etc.
Note taken though.
By evilowl
#2036449
Did you convert the map to UK format? If not I would suggest doing more research and not blindly changing things and thinking everything will be fine.
If you don't understand what you are doing then I would leave well alone if I were you.
By ryansss
#2049981
You CTR owners are lucky as I ran the cold air map fine for a year when I had a CTR, but now I have a DC5 and can't find anything like that for it. Don't fancy spending hundreds on rolling road setup as I still want more mods before I have it done properly :???:
By evilowl
#2077953
evilowl wrote:http://www.civictype-r.co.uk/forum/view ... &sk=t&sd=a
unfortunately the links are dead, so I'll have to see if I can dig out the maps. It was 4 years ago since I last saw them so they will probably be on my laptop somewhere
evilowl wrote:Here you go. I can't guarantee these *are* the original files but they look about right
Use at your own risk blah blah.
http://www.itsnotarace.com/CTRO/k20a2-c ... 151204.kal
http://www.itsnotarace.com/CTRO/k20a2-c ... ified1.kal
http://www.itsnotarace.com/CTRO/k20a2-c ... ified3.kal
This last one has definitely been modified because I increased the idle speed due to my ES mounts and disabled the launch control. I think I may have made other tweaks as well so if you're going to use it please check the tables!
http://www.itsnotarace.com/CTRO/k20a2-c ... vilowl.kal
By Sacrificial Pawn
#2191420
^^ You need to open the RSX map in notepad and change the ECU type.
Can't recall what number it needs to be, check another UK map, 'CTR tuned' for example. :thumbup:
Then resave as a .cal file. Upload, don't mention anything about it on Hondata forums :oops: , happy days.
