"this software is several months old and there is likely to be a newer version"
But I up to date.
How often do Hondata release updates?
Drucifer wrote:Do it before, you have to re-upload the kal at the dealers and TDI won't give you the map.Thanks! All done :thumbup:
evilowl wrote:When you get to the Honda dealer, you'll need a laptop running KManager software from the hondata website.Sorry if this sounds like a daft question but it’s regarding the immobiliser coding. Going off what you wrote does that mean the immobiliser will only work with the map that you have in place when Honda re-code the keys?
Open KManager on your laptop and select file>open. You'll get the list of maps that come with the software preloaded. Right click k20a2-rsx-coldair and select "open with" and choose notepad
Change the ECU type from 3 to 2 and click file>save in notepad
Now you can open that map in KManager. From the top menu select Parameters>misc. Here you can enable the immobiliser. Then select Knock/TPS and ensure the knock sensor box is ticked, and also tick the lower box for flashing MIL when knock is detected.
Now save the map by clicking file>save as and choosing a new name for the map (e.g k20a2-rsx-coldair-immob) . You can't overwrite the existing one.
Plug the USB lead from the ECU into the laptop and put the keys in the ignition, and switch the ignition on (but don't start the car). If you haven't ever connected the laptop to the ECU before the laptop will recognise the ECU and will ask for drivers. Choose to install the drivers manually and point the installation directory to the KManager folder (ie c:\program files\kmanager ) and click ok. It will then find the drivers and give you a warning that the drivers aren't digitally signed but click continue anyway.
When that's finished, in KManager click Online>Upload. It will take around 60 seconds to upload the map and you will hear a click from the ignition when it resets itself.
Now the Honda dealer can get to work coding the immobiliser. It should only take 20-30 minutes so you should be charged for a maximum of half an hour's labour at the dealers normal rates plus VAT.
evilowl wrote:Yes that should be ok, and yes you can upload another map once the immobiliser has been codedQuote to self: "Must not power read threads before I ask questions" lol
RobCTR wrote:So if your having a k100 fitted does this mean the immobiliser will be permanently disabled once fitted, as their is no connection point for the dealer to plug to? :scratch:I was wondering about this also? I don't think I'd ever play around with K-Pro sufficiently myself to justify the extra ££'s so was looking to buy a 2nd hand K100. Does anyone know the answer to Rob's question :scratch:
