Mind Over Matter...
By TazR
#113614
Are these of any use;
Connector A (31 Pins)
1-blk/wht-Primary O2 sensor heater control
2-yel/blk-Power Source
3-yel/blk-Power source
4-blk-Power ground
5-blk-Power ground
6-wht-Primary O2 sensor
7-blu-Crankshaft position
8-yel-Sensor return volt
9-red/blu-Knock sensor
10-grn/yel-Sensor ground
11-grn/wht-Sensor ground
12-blk/red-Idle air control valve
13-wht/blk-EGR Valve position VTEC ONLY
14-blk/wht-Secondary O2 sensor heater control
15-red/blk-Throttle position sensor
18-wht/grn-Vehicle speed sensor
19-grn/red-MAP Sensor
20-yel/blu-Sensor Voltage Supply
21-yel/red-Sensor Voltage Supply
23-brn/yel-Logic ground
24-brn/yel-logic ground
25-wht/red-Secondary O2 Sensor
26-grn-Top dead center sensor
27-brn-Igniton coil 4
28-wht/blu-coil 3
29-blu/red-coil 2
30-yel/grn-coil 1
Connector B (24 Pins)
2-yel-Fuel injector 4
3-blu-Injector 3
4-red-Injector 2
5-brn-Injector 1
6-grn-Radiator fan control
7-red/blk-A/T Pressure control solenoid valve A
8-red/wht-Engine Coolant sensor
9-blu/blk-VTEC Oil pressure switch VTEC ONLY
10-wht/blu-Alternator L Signal
13-wht/red-Alternator FR Signal
14-blu/red-EGR Valve VTEC ONLY
15-grn/yel-VTEC Solenoid valve
16-blk/red-A/T Pressure control solenoid valve B
17-red/yel-Intake air temp sensor
18-wht/grn-Alternator control
21-yel/blu-EVAP Canistor purge valve
Connector C (22 Pins) – AUTO TRANSMISSION ONLY
1-wht/blk-A/T Pressure control solenoid valve A
2-yel/blu-Torque converter clutch solenoid
4-grn/wht-Shift solenoid B
6-blu/blk-Shift Solenoid A
7-wht/red-Mainshaft speed sensor
8-brn/wht-A/T Pressure control solenoid valve B
9-red-Position switch D3
10-wht-position switch R
11-blu-position switch 2
12-blu/wht-position switch neutral or park
14-grn-countershaft speed sensor ground
15-blu-countershaft speed sensor
18-blu/yel-position switch D3 or D
20-yel-position switch D
21-wht/grn-mainshaft speed sensor ground
Connector E (31 pins)
1-grn/yel-Immobilizer fuel pump relay
2-wht/red-Secondary O2 Sensor EX Only
4-pnk-Sensor ground
5-yel/blu-Sensor voltage source
6-blk/wht-Secondary O2 sensor heater control EX Only
7-red/yel-PGM-FI main relay 1
9-yel/blk-Ignition input signal
12-blu/orn-Cruise control signal
13-wht/blu-Interlock control unit
14-lt grn-Fuel tank pressure sensor
15-grn/red-Electrical load detector
16-lt grn/blk-Power steering pressure switch
18-red-A/C Clutch
20-blu/red-EVAP bypass solenoid valve
21-lt grn/red-EVAP Canister shut valve
22-wht/blk-Brake pedal position switch
23-lt blu-K line
24-yel-Multiplex control unit comm line
26-blu-Engine speed pulse
27-red/blu-Immobilizer code
29-brn-Service check signal
30-red/wht-Write enable signal
31-grn/orn-MIL or check engine light enable
These, i'm not sure if they are for EP3's
Added By EvoStu : 19th May 2007.
Here is a simplified diagram of the K-Series ECU (thanks to Carl - N77).
EP3 - Pdf File (thanks to Jostrom).
http://www.mediafire.com/?bymdbpvmu8u
By steve_jones
#115925
Which bit are you unsure about the diagrams, or the Cable Colours lists :)
Steve
By stanwan
#115930
Anybody have an oscilloscope. I am wondering if we can wiretap the 02 sensor feed and see what it outputs. We can then sample it build an O2 sim. We also might need the primary 02 feed to compare.
Any takers?
By Annihilation
#115981
i reocn we can.. but the sim would have to fluctuate completely in phase and i think we would have to get the oem signal and then get the modded signal and then using osme resister knock its value down... its simple but might jsut work..?
By stanwan
#143363
Hi taz do you have the circuit layout for E connector?
By dieselpower
#143390
Stanwan, I've got an ocsilliscope in my loft. What do you want to do with it???
Andrew
By EMail4Jon
#294391
Can anyone let me know which wire is the speed sensor please?
Need to connect it to my gps (kenwood)
Also, is there a wire that outputs to the reverse light that I can take a feed from (low current) or should i take that from the loom?
By EMail4Jon
#294394
it's ok - just spotted it - white/green. thanks :)
By ant_2004ctr
#391103
Hi,
Sorry this is still a bit confusing - trying to wire-in my VTEC indicator - instructions in Jap !
Only have 2 wires and earth - vtec wires on & off - which points?
sorry if this is the wrong section to ask - experience most welcome! :oops:
By simon and kate
#417463
does anyone know which wire i would have to tap into for the 02 sensor sim for when you decat the car?
is it No-6-wht-Primary O2 sensor from connector A by any chance???
simon
By matthew.lewis2
#504253
Please see the below links. They are diagrams provided to me by my local Honda Dealership. Hope this helps. :D
http://www.freepichosting.com/Albums/421573973/0.html (connector A (part1)
http://www.freepichosting.com/Albums/421573973/1.html (connector A Part2)
http://www.freepichosting.com/Albums/421573973/2.html (connector B)
http://www.freepichosting.com/Albums/421573973/3.html (connector E)
By Harv
#1059095
:shock: :shock: :shock: My head hurts after looking at that
By hamedius
#1066903
the links ain't working any more :(
By gino11
#1234296
Does somebody still have the info from links above???!!!
By jostrom
#1466976
TazR wrote:Are these of any use;
NO, see next one.
TazR wrote:These, i'm not sure if they are for EP3's
THEY ARE NOT FOR EP3.
People DO NOT use these pinouts!! You will damage your car/ECU. They are not for EP3 CTR. The lists don't even match the pics and CTR does not have connector C, which is for automatic transmissions (see the pin names). EP3 CTR has connectors A, B and E.
By iceman
#3730655
anyone got uk ep3 pre face ecu wiring pinout diagram ? found some online but don't seem to match my ecu so want to be 100% sure have right one
need to know which wires are
speed
rpm
can use as earth
can use as power for heads up display
