03NHBtypeR wrote:How much would a custom setup like that cost and what would need to be changed? Whats the minimum recommend drop on Meisters? Up until now I have run Koni shocks on standard springs and it seems to work well but I've now broken my 2nd set of front shocks in as many years so I won't be purchasing them ever again. Need a new setup but don't want to go too low! Even eibach pro kit pissed me off and that's the lowest drop I could find
Drop us an E-mail at
[email protected]
In theory we can make the adjustable suspension as taller than standard if we want to.
It does depends on what you are after, we have a lot of option to choose from.
Depending on what we need, a custom setup maybe around £850 or so.
All the way up to £1800 if you want depending on the quality you are after.
Jerrick
