We didn't want to make something simply different, we wanted to make the best and compete with the best offerings on the market.
We have finally arrived at the finish line and the new MeisterR GT1 Coilovers are finally ready.
The GT1 coilovers are developed in collaboration between MeisterR and Black Art Design (BAD).
BAD is a well known British suspension company responsible for many race winning cars.
Their portfolio range from the DAX Rush, Noble, Classic Austin Martin, to the fastest privateer Ford RS200 in the Colorado Pike Peaks.
The GT1 coilovers have many custom in-house made parts that are truly cutting edge engineering.
As there are so many technical features on the GT1 coilovers, we are still compiling a presentation that can show off these features in an easy to read format.
But here is a little teaser video I made up for the GT1 Coilovers
The GT1 coilovers retail at £1650, and we want to provide a few benefits to members that may be interested.
Here are a few points we are thinking about and we want the community's opinion.
1. Life-Time Warranty on hydraulic function to the original purchaser:
That is right, the GT1 damper is built to such a high specification that technically speaking, unless it is physically damaged (such as a bent / scored shaft), it will continue to operate forever… even under racing condition.
However, parts exposed to the element will wear over time so you really can't give a lifetime warranty on those, but the actual damper itself will continue to function for years, we are that confident of the quality.
The warranty means, if you go to Nurburg every weekend and a damper failed after a run 3 years later, we will rebuild it for free.
If you crash into the Armco and bent the rod, or run into the gravel and scored the damper shaft causing the damper to fail, then it isn't cover. Sounds pretty fair?
2. Upgrade from Zeta-S / Zeta-R / Europa to GT1 Coilovers:
We feel that some MeisterR owners would want to upgrade to the GT1 in the future. So we want to make an upgrade program for those who have purchased the Zeta-S / Zeta-R / Europa coilovers.
Our initial thought is, you can purchase a set of GT1 coilovers, and after installation you can send back your old set of MeisterR coilovers and we will refund you £350 (Around 50% of the purchase price) for your old set.
That way you get a brand new set GT1 in your hand, and there is no need to try to sell the old set of suspensions or wait for a rebuild.
So what do you think of the life-time warranty and the upgrade option with the GT1 Coilovers?
Do you have anything else that you feel could be beneficial to the end user.
We are always open to opinions and suggestions.
Jerrick / Edwin
Use Voucher Code CTROC when ordering on www.MeisterR.co.uk
