#3620607
Ernie96 wrote:What spring rates are available in the ep3 kits?
Whats the max spring rate the shocks can take?
Whats the amount of height adjustment from max to minimum?
Thanks.
We have Zeta-R and the SuperRace
Zeta-R: 8/12
SuperRace: 10/14
The SuperRace has harder springs rate and 40% stiffer damping than the Zeta-R for race use. :)
Jerrick
#3621784
redep3 wrote:hi,
what was the problem with the straight arms and lsd :???:
Was an issue long ago with no clear answer. Some owner had issue, other do not...
The LSD cause pulling under acceleration... could be the LSD, could be alignment, etc.
In the end, we swap to the curved arms and all owners seems not to have issue with LSD.
So that is why we kept the curved arms design and have been offering the curved arm ever since.
Jerrick
#3622090
I currently have the straight arm ones and geo is done and when im going pretty fast and change lanes it feels like it pulls you about and drags you to the other lane!
one shock is leaking and can't get anymore camber on passenger side shock sits right over on the top mount here Image
This is how the drivers side is and that was fine to get camber :/
Would you recommended trying your newer fronts ?
