By dan121027
#195138
got mugen skirt on order so i think id like to lower the car slightly,i use the car everyday for work so i dont really want a much harsher ride, i know this is unavoidable but can u guys recommend any springs?
cheers dan121027
By HASNIC
#195353
I think there are three main options
1) ABP lowering and fast road set-up
2) H&R springs
3) Spoon springs
They all seem to be rated highly, the spoon springs don't drop it much maybe only 15mm and I think the other 2 drop 30-35mm.
Have a look at posts regarding the different springs and see what people maek of them and you should be able to get the prices aswell by having a look around :wink:
By GarethTR
#195535
If you are keen to keep the ride smooth you may want to consider a set of Koni dampers.
These chaps will recover ride quality regardless of drop, not cheap though, expect to pay £400-£500 fitted on top of lowering springs.
Give ABP a call on 01270567177
Keep it smooth........
G
