EP3 OEM B pipe to cat bolts
Posted: Sat Feb 18, 2017 6:22 pm
by CTR247
Hi guys,
I'm looking to replace the current aftermarket cat back exhaust system on my car (was on my EP3 when I purchased it) with an OEM B pipe and back box. I already have a new doughnut gasket and 2x nuts, bolts and springs to connect the the OEM B pipe to the back back and new 3 hole gasket that sits between the OEM cat and the B pipe but can anyone advise what size nuts and bolts are needed to connect the cat and the B pipe (has a 3 hole triangular flange)
Re: EP3 OEM B pipe to cat bolts
Posted: Sat Feb 18, 2017 8:22 pm
by tucker87
Not sure of the sizes but if you check on lings Honda you will be able to get them from there.
Sent from my SM-G935F using Tapatalk
Posted: Sat Feb 18, 2017 9:27 pm
by 15repyt
Any nut and bolt will do once you've knocked the old ones out of the cat.
Posted: Wed Apr 19, 2017 11:44 am
by JackEP3Premier
They are M10 Bolts.
