- Sun Jul 17, 2016 1:17 pm
#3858375
Hello guys I was hoping you could help me. I understand that if you put a exhaust manifold on that you have to get the car k-prod due to the car running leaner. And in doing so you have to get the keys recoded from honda. However I have a Clifford 650 with engine start in the car and basically one key is near the ignition barrel when installed to trick the car that the transponder is near the car to start. So my question is would I have to get the Clifford re-coded too? And the key out of the barrell for coding and then re installed?
Thanks would really appreciate the help
Sent from my SM-G928F using Tapatalk
