Bhp or Beefy Sounds...
By strtcpr
#2905913
I've only got a DC cat back, but was reading 103dB on static test at 4500rpm (the track i use has a very understanding tester who never seems to notice i'm not giving him the 5500 he asks for). Not sure what It'd be like on a drive by reading - the bung does make a difference though and drops it by about 5dB, however you also get a knock on impact in performance.
By R155
#2907746
glad i read this just scanning about for a new exhaust mainly for tracking, really don't need the hassle with balck flags having spent a fortune on a exhaust and trackday, cheers for info always helpful CTR forum :cooldude:
By sendai
#2908425
I run 4-2-1 headers/decat and buddyclub pro spec 65 mm. the car is pulling very very good but I can't run this setup on the street anymore cause is far too loud.
.....so for now I put the OEM catback on for now, untul I will modify the oem back box with 65mm internal pipes and some weld job to joint with the buddyclub b-pipe.
....anyway....the car drives like s...et. I loose torque and power. A LOT! the AFR figures are ok, in the range.
On track days I put the buddyclub back on, reset ECU and reload the map. the car is 100% changed :thumbup:
I use the buddyclub only on track for now. In Italy we don't have noise regulations for track days but on the streets the police is hunting us down for every single mod :bad-words:
By Bud
#2912343
sweatygooch wrote:Has anyone run an N1 backbox with one of the unsilenced b-pipes in the For Sale section? How would it compare to BC spec 3 catback?
I had a unslienced bpipe and N1 its seriously way to loud. You cant even think when your driving :lol:
Spec 3 is just as loud
By Mouthwash
#2918353
At 5k RPM my N1 with an unsilenced pipe was 116 DB..... Quiet.
By thorny88
#2919950
thanks, been wanting to no this as im running the same. Was that test conducted at a track?
By Mouthwash
#2920213
No I got a decibel meter and tested it at home.... so may not be 100% accurate but it gives you an idea. :)
By 1534walla
#2939661
Marcus R wrote:Any idea what results a BC Spec 3 + DC mani will produce?
ive got this combo an its WAY too loud, sounds nuts in vtec though :roflmao:
By SeanEP3
#2949195
can i get a decibal reader on the iphone? will it be accurate? i want to giggle at my DB level
also, my car has launch control set at 3500, so how would they test it?
mugen mani + mugen sport cat + pro spec 3 = bleeding ears :thumbup:
By Bud
#2956915
ctr-lib wrote:hi what will a
race header- spoon b pipe- spoon n1 come out at
im in the mist of buying a spoon n1 but im doing some track days soon and i dont want a black flag
About 110ish
  • 9
  • 10
  • 12
