Let it breathe...
By TheRedBaron
#33129
Im going be getting a quickshift induction kit,
how do i take out my old filter-
what comes out and what stays in?
then how do i fit the new one?
do i need to fart about with the ECU or will it take care of the changes its self?
i suppose the best answer is get a garage to fit it! :oops:
:wink: :lol:
By Redcap
#33143
It takes about 10 mins to do so I think getting a garage to do it is a bad idea.
Anyone got a description of how to do it?
I would give a description myself but mine is the HKS so it's abit different.
Maybe PM TazType-R as he is very helpful, has most things like this and had one fitted. :wink:
By TazR
#33156
Here you go, any questions please PM.
Unscrew airbox lid.
Remove screws in base of filter housing x 3?
Lift the original air box out, after having loosened pipe/clip to cam cover and MAF sensor.
Fix the long bracket to the screw hole located on the left, used by one of the original screws in the airbox
Fit the metal tube you'll see what I mean when you get it, to the MAF sensor pipe, lightly tighten.
Then fit the red breather pipe on to the cam cover
Then attach the filter to the other end of metal tube, lightly tighten
Connect other end of the red hose to the filter
Locate threaded section on the metal tube into hole on the upright bracket you secured earlier
Position everything carefully then tighten every thing up and Voila!!
ECU will adjust to any mods like these after about 30 minutes driving (50 miles) according to driving style.
If you want to speed the process up, remove the fuse to the ECU prior to fitting and put back when complete.
By TheRedBaron
#33253
cheers ill give it shot.
By philip
#33502
comes with instructions,plus i have no hands and still fitted it,using my feet.
phil silver ctr
By TheRedBaron
#33725
was it your feet or your
smart arse? :lol:
By phillip pitt
#33929
hi where do i get one and how much
By EvoStu
#33940
phillip pitt wrote:hi where do i get one and how much
http://www.motorsportworld.co.uk
£102.00 delivered.
I'd get your order in now mate cos they tend to run out very quickly.
EvoStu.
