- Wed May 27, 2015 1:19 pm
#3832071
I have had 2 scuttle panels fitted with my tegiwa,the first one was fitted by a garage and it did rattle a bit,and was a bit untidy.
So I decided to buy another one along with the scuttle panel insert.
As mentioned above it depends how you fit it and cut your scuttle panel,its a pain to do and you just need to take your time with it.
Finally I am now happy with the fitment and theirs no rattles.
Tegiwa now have instuctions on their website on how to fit the two parts,take a look.
I prefer to hand wash the car myself and would not take it to a car wash,to cut down on scratches.
I normally just push a carrier bag in the scoop to cut down on the water going in and never had any issues,the filter part sits at the top anyway.
I would recommend the scuttle panel insert otherwise you will be left with a gap which does not look very good and you will loose cold air through it as well.
I also purchased stainless steel black coated bolts for the scoop as the other ones had started to rust.
Hope this helps.
