- Fri May 22, 2015 3:58 pm
#3831698
Hi,looking for some advice i have an Rbc manifold and a tegiwa airbox with scuttle panel insert.
I have just purchased a Tegiwa hose to fit between the throttle body and the airbox as the angle of the Honda pipe going into the airbox was not great,and the hose was split at the throttle body end.
I believe you need to trim some of the silicone hose to get it to fit correctly.
Can anyone advise me what end to trim and how much to cut?
I tried fitting it to the car and the bracket on the the left of the airbox does not line up and the airbox sits a bit high.
Thanks in advance for any answers.
